MATCO brake discs
benjam
Active Member
Hi All,
Can anyone offer advice on the tool to remove the bolts from this MATCO discs?
Torx drive, but T27 is too small, and (next size up) T30 too big?
What would you replace them with if you accidentally flogged it out trying to tighten it up? The black bolt on the right is high tensile but a different drive head.
asking for a friend…😳😳
any advice out there please?
I had those internal-caliper Matcos for many years on my -6 and the rotors were retained by Allen button heads (like your black one). Just be sure to get new Nord-Lock washers.
I’m looking for a standard milspec for this button head cap screw. Can anyone tell me what it is? Matco part is MSC.25-20X.75BHCS but ordering through them will take too long (I’m in Germany). Who can say what this size and thread is - or give standard AN or mil reference?
The secret decoder ring --
MSC - Mil Std/Spec, CAD
.25 == 1/4"
-20 == 20 TPI
.75 == 3/4"
BH == Button Head
CS == Cap Screw -- Either TORX T25 or ALLEN Hex.
A note on Torx Plus... you can undo a torx screw with a torx plus bit, but you can't undo a trox plus screw with a torx bit. I installed the torx plus per Matco's latest recommendation. I later switched back because I was afraid one day I would get caught somewhere and not be able to get them off. If I recall, the impetus is be able to apply greater torque (which is not needed - see below) and less wear of the screw head.
Another BIG caution on Matco inboard wheel halves... do not over torque the brake disk screws. The threaded aluminum wears after years and the threads get a little sloppy. Always use new Nordlock washers and a little medium Locktite. I had two screws strip out and depart while in flight and the remaining screw let go on landing. Great fun when your rudders are ineffective below 20 kts and you don't have any flaps. I ended up replacing the inboard wheel halves of both mains when I took a closer look at the conditions of the threads. I'm pretty careful about torquing correctly... but you never know about the previous owner or shop who may have worked on the plane.
MTCW
Just like Don's story above; I've had the new design screws back out in flight also. I chose to toss out the convenience of not having to deal with safety wire and reinstalled the old style bolts. I just don't trust them.
Hi All,
.25 == 1/4"
-20 == 20 TPI
.75 == 3/4"
BH == Button Head
To add some definitive info to this thread, the Matco rotor bolts are in fact Torx Plus. The "BHCS" in the secret decoder ring seemingly isn't accurate in this case because these fasteners use T27IP Torx Plus. Here's the fastener on Matco's site. I've confirmed myself they are T27IP. T25IP is too small for these.
Matco sell both a 25IP and 27IP Torx Plus bit, so other rotors or Mtaco components might use 25IP.
This Torx Plus bit socket set is made in Taiwan and appears to be of good quality. Torx Plus is not a common fastener (in my experience) but who doesn't want more tools?
