Marking Torqued Nuts
doctornigel
Active Member
What is everyone using (and where to get it) for marking nuts after they have been torqued. I assume it cracks if the nut loses it's torque, thanks.
Thanks for the link, that's what I wanted, just wondering if my daughter's cheap nail poligh would work, the torque seal is cheap enough though.
Torque Seal
You can order it from Avery Tool (Torque Seal). The non technical name is Tattle Tail. I use it to identify nuts that have been completed/torqued. Over time it will crack and that's fine. What your looking for is rotation between the nut and screw or surface location. If you see rotation then something has moved and should be checked.
Pat Stewart
RV8
RV8A
RV10 Building
J3Cub
