Today, I started my 9A, with the 0-320 engine and constant speed prop. The AFS 5600 EFIS showed a MAP of “27” when I turned on the master switch. It immediately went to “- -“ as soon as I started the engine. In addition, the amp meter jumped up in the red to “49”! I shut it down, checked the #3 cylinder connection (no issue) and the AFS sensor wiring. Did not find any loose connections or connector pins missing or broken. Does anyone have any suggestions or history with this issue? I will be grounded until I can come up with a solution. There are no wrong suggestions. Hope you can help.
