Rpm excursion, my 2 cents. Long
Hi Kevin,
I have read this thread and would like to throw in my 2 cents worth. Like others, who have followed your building progress for years, I am happy that you and your plane came through this episode in one piece. I don?t have an answer as to why your oil pressure dropped during this test, but it is an anomaly with your plane. There are many other RV-8?s similarly configured that do not have this problem. My plane is a case in point. I have an RV-8 with an IO-360 M1 (with forward facing sump off an IO-360 A series Lycoming), a Christen inverted system, and a Whirlwind 200 RV propeller. My oil sump is the same as yours and has the oil screen and extended sump modification from Christen. Bart at AeroSport Power assembled my engine.
I was initially concerned that the propeller might run away during transitions from positive to negative G?s and back, due to temporarily low oil pressure as the ball-valve in the inverted system switched. I have observed this phenomenon regularly in my Jungmann with a Lycoming and Christen system; the oil pressure drops temporarily from 70 to 40 psi and then pops back to 70, when doing G transitions. This causes no problems with a fixed-pitch prop.
Like Danny King, I installed an oil accumulator in my RV-8 to maintain oil pressure during G transitions. The combination of Christen system and accumulator worked well during both positive and negative G aerobatics with no propeller excursions. After a couple of hundred hours, I decided that the RV-8 is not well suited to negative G maneuvers and sustained inverted flight, and I removed the accumulator, which had a persistent oil seep that I couldn?t seem to fix.
During the past 300 hours, I have flown hundreds of positive-G maneuvers, including Cuban 8?s, hammerheads, and all kinds of loops and rolls, with the Christen system and my Whirlwind 200 RV non-aerobatic prop. I have never experienced low oil pressure or any rpm excursions during these maneuvers. I normally run my engine with the dipstick showing just under 6 quarts; if I fill it to 8 quarts, it just pukes the first two quarts fairly quickly.
I have no idea why your plane behaved as it did, but I don?t think that you need to buy an aerobatic propeller to fix the problem. There must be some other problem either with the Christen system or with your oil pickup in the sump.
Best of luck finding the problem and getting back into the air. Please keep us posted on what Bart finds during the tear down of your engine.
Best regards,
Dan Miller
RV-8 N3TU 500+ hours
