Main landing gear attach point bolt torque values
didja
Active Member
Looking for some help with torque values on the main landing gear to the wing box area. The bolts are NAS 1305-19 at the top of the gear attachment angle and the two NAS 1305-36 bolts on the bottom for the gear attachment bar. The torque chart in the front matter does not list these. Thanks.
I found a chart online based on the size of the bolt. It stated that the 1305 should be around 110 in-lb and the larger 1306 should be 200-250 in-lb. Does that sound close?
