If you see my other post, Divco thinks I have middle main fretting (common) that will likely need rework. Thinking about doing Lycoming SI 1290, reaming and oversizing the thru bolt. Anyone have success with this? I have an -E2D which the SI is applicable, but it was upgraded to 160HP at overhaul in '93. After some searching it appears this can work for 160HP but may not last.
My goal would be to let things squeak by a little longer until a full overhaul is required. Right now everything is running really well but this oil leak is little too much for my liking.
