Lycoming O-320-E2D with RAM 160 STC and Electroair EIS-41000
Jwylde
I'm New Here
Is anyone out there running the Lycoming O-320-E2D engine with RAM 160 STC and the Electroair EIS-41000 ignition system? My concern with this setup is the higher compression with the stock timing of 25° BTDC will increase the CHTs, and adding the EIS with electronic advance will also increase the CHTs.
For those running this setup, what CHTs are you seeing?
Thanks in advance.
I’m running an 0-320 with 9.5:1 compression ratio pistons, your 160 hp is 8.5:1. I run dual Pmags with the base timing set at 25 btc. I have no issues at all managing CHT’s. If your cooling system is reasonably descent and it’s getting plenty of fuel, your setup should be fine.
