Lycoming IO 540 G1C5
That engine is an angle valve and 40-50 pounds heavier than the recommended parallel valve engine. It?s also a bit physically larger so likely an issue with the cowl. So, it would take a fair amount of work to make it fit, then you?d have a serious CG issue.
