LP4-3 Rivets substitute
LeoKenner
Active Member
Patron
Is there anyone other than Van's that sell these?
Or is there a substitute that is readily available?
Google GSMD41-43APG
A "LP4-3 rivet" is typically a type of blind rivet, often referred to as a "Gesipa GSMD41-43APG PolyGrip rivet," which is used in construction and manufacturing applications where access is only available from one side of the materials being joined; the "LP4-3" designation likely indicates a specific size and grip range for this type of rivet
For any of these - check the strength and materials to ensure compatibility.
Also, if it's an RV-12 (-12iS) that it's going on, there are specific rules for where your parts come from. I think those are limited to Van's parts, unless it's not going to be E-LSA.
Dave
This is true, but only during initial construction before the airworthiness cert is issued. After that, anything goes, just like any other experimental.
