BillL
I am wrestling with the right balance for trimming the cowl cutouts and top of the gear fairings to allow installation of the lower cowl.
If I lift the cowl parallel or nose high, it binds on the gear fairings as it is lifted (while the nose is against the prop). I will worry about scratches later, for now it needs to fit.
How did you do this - any pictures, links?
