Started up this morning and trim position indicator had disappeared from my D180. Trim is working normally. Everything else on the EFIS page is unchanged. Not having built the aircraft, I'm not sure where to start looking. Is it likely to be settings issue with the 180, or the loss of a connection? I'm gradually coming to understand the inner workings of the 180 but still not proficient on options deeply embedded in the menus. Recently I managed to make a display change in the EMS, replacing an OAT display with an amps indication (next to voltage). Just in case there was a connection I reversed that after trim indication disappeared, but to no avail.
Jack
Jack
