I have completed the empennage build and just took delivery of the QB Wings and QB Fuselage. It's a great day; the hangar is very full of new parts. I am going through each Section of the instructions trying to assess exactly what has been completed as part of the QB and what is left to be done. I'm also trying to avoid doing anything out of order that might set a trap for later work. Sections 13 - 17 look very complete. Can anyone share their notes or experience on tasks that needed to be completed in these Sections?
Section 13. Main Spar
Section 14. Wing Ribs
Section 15. Rear Spar
Section 16. Top Wing Skins
Section 17. Outboard Leading Edge
Section 18. Fuel Tank. The Fuel Tanks appear complete except for fuel level sender installation and pressure testing.
Section 19. Stall Warning System. I will have an AOA sensor as part of the Garmin G3X; is it worth having the stall warning system too or should I not install it?
Section 20. Bottom Wing Skins. Should I delay riveting the outboard bottom skins until after after the aileron actuation system installation is complete?
Sections 21 & 22. Ailerons and Flaps. Looking to see if anything is left to be done with the Flaps and Ailerons (it's a little more difficult since they are on back-order).
Section 23 Aileron Actuation. Sections 23 appears to be the first of these Sections that needs doing in its entirety.
My apologies for the long post, but any guidance from your experience would be greatly appreciated.
