Longer rod end bearings available at Vans
dmuro2
Member
Patron
Just spoke with Kevin at Vans Tech Support and he wanted folks to know that if you're worried about thread engagement and wish your existing rod end bearing was a touch longer—Vans sells rod end bearings that are the same in all respects, except 1/4" longer.
We talked about one rod end bearing in particular (mounting the elevator to the horizontal stab), so you may need to call the parts team to inquire about others.
Original — MD3614M
Longer — Bearing MM-3M-42
Thank you Kevin!
That is all, carry on.
Original — MD3614M
Thank you Kevin!
They have had them for quite some time now. I bought a few last year and bought some before that. Good reminder though.
