Legacy AV-50000 Diagram/Pinouts Needed
Anyone have the pin outs / diagram for the old AV-50000 board?
Your previous posts indicate you have the legacy 12 with the D-180. If you have the D-180 you have the “AV CONTROL BOARD 12” not the AV-50000. The AV-50000 was used with the newer Skyview or G3X on the legacy 12 after the D-180 was discontinued. Currently the RV-12iS uses the AV-60000.
Here’s a copy of a straight line schematic for the D-180 version.
Just posting it here in case anyone has any experience doing this - needing some assistance with installing a Garmin GTR-205X and what connects to what. Looking to preserve engine alerts and isolate/remove the Vans intercom system. Thanks!
Still not sure if you have the legacy 12 with the D-180 and the “AV CONTROL BOARD 12” or the AV-50000 used with the newer Skyview or G3X on the 2nd version of the legacy 12.
I did the engineering work to upgrade the SL-40 to the GTR-200 on a legacy D-180 RV-12 a few years ago. It’s pretty Involved, the engineering alone was about 40 hours work. Unfortunately the GTR-200 went obsolete before I could follow through on the upgrade. So the attached file is just a preliminary document. I didn’t have the ambition to redo all that work and follow through with the replacement GTR-205 upgrade. No guarantee there aren’t errors in the file. A quick look shows the new com stack brackets you need to fabricate for the GTR200 aren’t compatible with the GTR205 tray. And of course the connector and pin locations of the two different, but the signal names are similar so it should be easy to remap.
I have some brackets that are very different than the ones shown in your diagram that should make mounting a bit easier. I think I'm more nervous about the wiring connections.
