I found a leak on my left tank, and traced it down to the fuel pickup. After draining the fuel and pressurizing the tank with air, I found bubbles coming from around the fuel pickup. I disassembled and installed a brand new VA-141 I had lying around with Loctite 567 thread sealant. Let it cure for 24 hours, leak tested and reintroduced fuel. Now a week later it's leaking again. Stuck a borescope down there and there's still a ring of the thread sealant around the fitting but the thread sealant on the top side is tinged with blue dye.
Vans says to use 567 for thread sealant, but I'm suspecting it's not curing properly. Is there another sealant that's better? I was reading the datasheet and apparently we need an activator to go with the Loctite 567 when applying on aluminum?
