Thirty hours on new engine
I was testing for leaks in the fuel system as I had noticed a fuel spot on the floor after the last flight after shutdown. Throttle 2/3, mixture cutoff, boost pump on and I get quite a bit of fuel out of the fuel pump from the overflow line onto the floor. Is this normal? After thirty hours I have never seen that before. Thanks!!
