Going through my landing gear alignment on my -14A last night and it appears I have about 1.5 degrees of toe out on each side. While this seems fixable, I wonder if there is anything that I could have done to alleviate this during the build. Is this mostly a function of twist in the gear legs themselves? I don't see what I could have done differently to reduce this. What are outher builders experiences?
I will also point out that I had no room for the shims in the upper gear attachment. That upper bolt was a challenge to get in as it was and was not accepting a shim in there. But I don't think this should affect the toe.
