Toobuilder
Go get some time in a -9 and then we'll chat.
So Sig and TB, wanna call a knock-it-off to this 1v1 dogfight yet?...
Anybody held a 9 fully stalled, keeping it straight with rudder, to see what sort of vertical speed develops ?
...Would something like this be a possibility for an engine fire which would not extinguish with speed ?
Rupert
With the -9 I fly, it will not fully stabilize with the flaps up no matter how long it is held in the condition.
Great thread Bill created thank you. I am a low timer and enjoy reading it a lot of food for thought. Keep talking gentlemen.
When coming in high, a pilot has a few options. 1. Go around, 2. Slip, and 3. Raise the nose.
By taking option 3, you can slow the plane without stalling it and it will develop a high sink rate. Once back on the proper glide slope, lower the nose and resume your normal approach speed.
This is just another arrow in your approach quiver.
And there is nothing wrong with option 1 either. It's something you should practice anyway and it can be fun, depending on how you execute it. But you boys already know that don't ya?
Will I try it again? Probably, as I think it certainly is a good exercise in understanding the limits of the airplane and making me a better pilot, but it will be by myself, with plenty of altitude.
cheers,
greg
I took transition training in a 6A with Mike Seager earlier this year. We did some stalls and as I was trained years ago, I used rudder to raise any wing drops. Decades ago, I inadvertently used ailerons during a stall in a Cessna 150 with my instructor at my side. I was amazed at how fast I went from looking at the sky to looking at the ground!
Anyway, my recover in the 6 was sloppy but it worked. Mike showed me how to do it with minimal feet...he just did a quick wiggle of the stick and we were flying again. I did the same and it worked. He said that on a 6, the ailerons remain effective in a stall. Is that the same on a 9?
I worry that if I "unlearn" using my feet I might one day get into a stall with a plane that will bite if ailerons are used which would be bad. Any thoughts?
...Let me rephrase, if ailerons are used to correct a slight wing drop on an RV9, will things get worse like in a 150?...
Flaps down however, the airplane simply shudders in the stall. ANY relaxing of the back pressure will allow the same stall, recover; stall, recover behavior as with the flaps up. The only way to make it settle down is to bring the stick to the stop and hold it there. Keep the ailerons centered and pick up a low wing with rudder. In my demonstration of this, I get high enough so that I can hold it in this condition for at least 30 seconds. Pretty soon you will find that you can not only keep wings level with rudder alone, but do significant heading changes with a fair amount of precision.
Andrew, my expertise is not aerodynamics
...Not that rudder isn't the right answer for keeping the wings level, but holding backstick and adding rudder is the textbook method to enter a spin. Rudder is a tool to keep the wings level during recovery.
Acrobatics - Arobatics one uses wings and engines, the other ropes, people, and running. Good catch!
It's in the RVator... "Like any other airplane..."5,743 views and 80 posts on landing a 9, it can't be all that complicated.
...I experienced similar disconcerting action when my instructor ( also new to RV's) was checking me out in my new -9a.
He was flying, trying to hold it in a full-power, full-flap stall, as far as I can recall...
...My point in commenting is that it may not be a docile as some expect in extreme aerodynamic situations...
...He was flying, trying to hold it in a full-power, full-flap stall, as far as I can recall.
we were descending when it suddenly 'snapped' forward past vertical, pulling about -1.5g. He recovered, but took up about 500', and we didn't explore that regime further! His recommendation?...' don't stall it just for fun'...
He was flying, trying to hold it in a full-power, full-flap stall, as far as I can recall. we were descending when it suddenly 'snapped' forward past vertical, pulling about -1.5g. He recovered, but took up about 500', and we didn't explore that regime further! His recommendation?...' don't stall it just for fun'.
Can you say tailslide? He did not enter the stall properly - he likely had too much speed pulling into the power-on stall, got very steep and let it tailslide. The pendulum down would put you slightly negative. Lucky you didn't bend the flaps. If his conclusion was to not stall the airplane for fun, he needs a debrief, and a review of his experience and technique. A properly entered power-on stall with correct rudder usage will result in the nose dropping straight ahead very gently back to level flight (nose won't even drop below level flight attitude). It will not snap over, and you will lose little, if any altitude if done right.
I'd like to point out that the stall behavior that you and your inexperienced instructor observed was the result of a pretty extreme and unlikely flight condition. Stalled with full flaps AND full power is way more radical than a simple 1g power off stall.
I generally ease into the stall behavior of a new airplane a bit slower than you guys did, but good for you to go out and explore the envelope. However, I really can't agree that future stalls "for fun" should be avoided based on your single (and fairly radical) data point.
With full power on, the only way to stall an RV is with a high G load or very nose high attitude. It will not stall if anywhere near level flight as air speed remains well above stall speed - with or without flaps.
Watched a Piper Cherokee crash in 1996 on a go around, full flaps, full power...
Not saying it can't/doesn't happen... But full power and full flaps in any light airplane (especially an RV) is pretty far outside the bell curve for normal ops, even on a go around.
