Koger sunshade size for -7A tipper
Draker
OK, I’m gonna break down and get a Koger sun shade. Even a short taxi under that canopy bubble in >100deg direct sunlight is drenching me in sweat.
Spruce sells two sizes that claim to fit the -7A tip-up: 30"Wx 25"L and 35"Wx 25"L. Is there any good reason to go for the smaller one? The larger one looks to be made for the -14. Has anyone installed it on their -7 successfully?
Slap shade too
Get the larger one. I’ve had mine for 2 years and use it 90% of the time. I also use a slap shade to place in various areas. Both well worth the cost.
I started with the smaller one from 2008 (that was the only size they had back then) and then upgraded to the large one about 2 years ago. I'd definitely get the bigger one. (this is a -6 slider)
It only adds this much ___________________________ to each side. get the wider one. You will benefit from it. It will fit just fine.
