Leaving MS
Wednesday morning I left MS/LA heading north. The sky was overcast so I couldn't fly very high.
After 721 miles I was getting tried, so decided to call it a day in Milard, NE.
I had a great meal that night at the Hawthorn Suites restaurant and a restful night.
The next morning I headed back to the airport only to find the ceiling to low for VFR fight.
I continually check the report from airports around the area. It finally look OK to head West. The sky at Milard was 2400 and although the airports to the south were below VFR the ones to the West were reporting 1500 to 1700 ft.
Off to the West I headed.
The reported condition were not what I found. I was feeling go about my panel about then. The AFS 3500 was showing the obstacles with nice colors. The iPad was showing my sectional chart so I would watch for tower and such. Good double checking. Even with this information I could not relax and enjoy the flight as I was not very far above the ground.
After 70 miles I decided that it didn't make since to continue, so headed to the nearest airport York, NE.
I announced my intentions to land. The FBO came on the radio and told my that runway 17/35 was closed for construction, but that I could use the turf runway 5/23. Well the winds were about 15 kts out of the South, but I didn't want to continue.
I was a rough landing and I taxied very slowly until I got to the pavement.
After waiting a couple more hours, the ceiling reports to the West again looked OK.
I asked if I could use the part of the runway 17 that wasn't being used, as I could take off in a short distance. I was told that I could use the taxiway if I wanted. OK.
Well it worked out the same as my last flight. Ceiling kept coming down and were not as good as reported. I finally gave up for the day at Kearney, NE.
The next morning I didn't rush to get back to the airport. I kept checking ASOS from the hotel. Around 10 AM it was reporting 1500 ft, so I headed back to the airport. Only 30 miles to the West the reports for clear skies.
We I got to the airport it had dropped back to 800 ft. So more waiting.
Just shortly after noon it was reporting 1100, but there were holes. So I started up and ascended through one of the holes.
Heading South it was solid overcast to the East, but broken to the South and clear to the West.
That was the last of my weather problems.
My stop in Dalhart, TX was a good time for a late lunch. They had a cafe on the airport. I could believe my luck. They make real milkshakes. You know the kind that they put ice cream in and mix in a metal cup.
After a cheeseburger and a milkshake I was on my way.
Since I had been delayed in NE, I decided to give up on the Leadville to Death Valley. I changed my CO stop to Durango. I had a stop in NM only 40 miles away and then on to Durango.
This is the Rockies as I flew across NM.
I wasn't over the tallest of the Rockies. The ones around me were only 13,000 ft. I was flying at 14,500 ft. I also decided not to fly direct to Durango, but went a little more South. My path was close to Taos, NM.
A couple day early I got a call from Rob Hickman (AFS), when he head about my AP not working. He told to make sure that I didn't start moving the plane until the EFIS and the AP had finished starting up. By doing this the AP was now working correctly.
I did discover that I didn't like using the AP when near the mountains. Because of the mountain wave effect the AP would go through cycles, when the updraft came the AP would head down hill and cause you to speed up, just about then there would be a change with a downdraft and bumps. Then the AP would head back uphill and slow down.
I found that I would get a smoother ride if I kept the plane level in the updrafts and downdrafts. The average out and I wouldn't be going to fast when I hit turbulence.
Coming into Durango.
![](/proxy.php?image=http%3A%2F%2Fimg7.imageshack.us%2Fimg7%2F3877%2Ff6durango.jpg&hash=d9d906a14af426def77a41aded3e9c25)
