I'm trying to decipher the first page of the James cowl instructions. From what I can figure out they want you to figure out the midpoint line of the cowl openings then use those lines to cut/file down the front so it is all in a nice level line. Then you attach that lower cowl to the plane and trim the upper cowl so it matches up. Is that right?
My issue is that I can't make a nice straight line across the midpoint of the openings because there are points in the fiberglass that are already lower than that line. The first pic shows a big view of the situation and the 2nd pic is a close up of the trouble spot. I can cut/file the front down so I have a line even with that low spot but as you can see the line would be at least 1/4" below those midpoint lines. I'm not sure if the upper cowl has enough material to match up with the lower cowl if I cut that much off. How do I proceed?
[/IMG]
[/IMG]
![il9evn.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi67.tinypic.com%2Fil9evn.jpg&hash=8e90120fba705791bb675e4bb462a1d5)
![2ivcsbk.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi68.tinypic.com%2F2ivcsbk.jpg&hash=2c628997f08e4767564369740d837a08)
