With all the boxes from a kit there is enough material to build a work bench.My wing kit finally arrived! And the spar crate is loooooooong. Is it potentially useful later into the build? Wondering if I should get rid of it or flatten and keep it for a while.
If you feel you might be running out of space, remember that once your wings are finished you need to store them somehow, likely upright. I used something like this before I found a hangar where space wasn’t an issue anymore.I feel I'm quickly running out of space for another work bench![]()
Save the crate! Makes a great central piece for wing stands. Sorry, the photo is gone. Outriggers with casters, vertical pieces from other Van's crates, tow straps hanging down to stubs on the ends of the outriggers to hold the wings. I even stored my tailcone on top above the wings while building the fuselage central section.My wing kit finally arrived! And the spar crate is loooooooong. Is it potentially useful later into the build? Wondering if I should get rid of it or flatten and keep it for a while.
You’re gonna need a bigger shop….I feel I'm quickly running out of space for another work bench![]()
