Bill_H
170 Hrs, Battery arrived in late 2011 so ~4 years old.
So recently I didn't fly for about 5 weeks. I leave the battery on a maintainer. I get in and master on - and the voltage is low, about 11.8. It barely cranks but she starts up and the voltage goes up and it charges in flight. Made three short hops that day - 15 min, 15 min, 15 min, and the the charging current started out high and went down. No problem with the subsequent two starts and voltage was above 12.
Popped the cowl and all connections are good.
Ending voltage with engine off was good - 12.3 or so. So I plugged in the maintainer again (after "rebooting" it just in case.) After a few days, the battery voltage (maintainer disconnected) is now 12.2.
I turn on the master, with fuel pump on, and it drops to 11.8. With avionics master off, Skyview shows 4 amps being drawn, which is typical for that condition before engine start.
Master off, the voltage is back to 12.2 at the battery.
Comments?
Comments?
