IO540 Mag Spacers
Warbirdsolutions
Active Member
Those of you with experience with dual magneto ignition should be able to answer this question: Do both the impulse coupled and non-impulse coupled mag use the magneto spacer between the mags and the accessory case?
Brad
P/N LW-12707 should be the part number for both sides for both impulse and non-impulse magnetos
FYI- The impulse mag is no longer supplied on the 540 due to problems, it was replaced with a dual point mag with slick-start.
Mag Spacers
Thanks guys. I am familiar with the impulse coupler issue. There have been differing opinions on the spacers though I think because the 4cyl only uses it under the impulse coupled mag only...
