sbalmos
Hi all,
Going to try to set up my gauge ranges on my G3X Touch for my IO-320 engine this weekend. From what I've gathered out of the IO-320 Operator's Manual, and a little bit of anecdotal research, I've got the following so far. I'm looking for opinions or what you have set up.
CHT: Redline 400F max, yellow 370F-400F (temporarily will be 385F-400F during break-in), white below
Oil Pressure: Red below 25 PSI, white 25-80, yellow 80-115, redline 115 PSI
Oil Temp: White 140-200F, Yellow at 200F, redline 220F
Fuel Pressure: Redline 45PSI, Yellow 40, White 12-40, Red below 12 (FYI, this an EFII injection/ignition system with the fuel rail design)
RPM: Redline 2800, yellow 2750
Thanks!
Thanks!
