I impluse-bought a nice 430w here yesterday. It arrived today complete with mounting tray and connectors. My RV4 is equipped as follows:
- Garmin G3X Touch (10" w/ Sirius XM Music/Weather)
- GPS20A WAAS (GPS Navigation/ADS-B Position Source)
- Garmin GDL39 (Remote Mount- ADS-B Traffic and Weather)
- GEA24 (EIS: Engine monitoring and annunciation)
- AUTOPILOT (2 Axis) GMC 307 (IAS Hold, VS and ALT Select,
- Garmin GSA28 Servos
- Garmin SL30 (NAV/COM)
- Garmin GTX23ES Transponder (ADS-B OUT)
- PS Engineering Stereo Audio Panel (w/ music control)
The previous owner left a 430-sized hole in the center console between my knees with the intent of eventually adding a 430. Now seems as good of a time as ever.
My goals are: Fly legal RNAVs and add a second comm. I have VOR capabilities in the SL30/G3x and the airplane flies a coupled approach just fine. I'd prefer not to add more antennas to get 2nd VOR working, unless there's a compelling reason to do so. I don't intend to spend much time in actual, but would like to be able to pop through a layer on days I'd normally be stuck on the ground.
I'm an instrument-rated pilot who rarely flies in actual, and when I do it's in a GNS-480 equipped steam gauge Cherokee which I use for currency and a modicum of proficiency.
Ideally, I'd like to run the 430 'headless' off the G3x as an external nav source, pushing flight plans to it, loading approaches and holds, etc. The seller of the 430 says this can be done with the newest software update.
It seems like now might be a good time to add a backup G5 or GI-275, as well. What else should I be considering before I talk to the avionics shop? I've started reading the G3x and 430 install guides, but I thought I'd ping the VAF hive-mind for some real-world opinions.
Here's my panel for reference. You can see the void below the SL-30. I'd likely bump the intercom and nav radio down and put the 430 on top. The Dynon D2 is inop and has been removed. I could put my backup instrument in this space.
