Trying to correct the popping and irregular idle on an IO-360 (Bendix system), I am to the point that I believe insulating the distribution lines would help. Since I believe this is occurring as a result of the fuel in the lines flashing and pushing fuel into the cylinders at a sporadic and high rate, insulation seems to be the next step.
However, I have heard here and there, that this is not recommended. Why? Mine are braced very well using at least two points of attachment though the run. So I can't see the added mass being a dynamic issue.
If it's about inspecting for damage/cracks, etc., this can be done occasionally if the insulation is made removable (gotta figure that one out).
If anyone has info or experience with this, can you please pass it along?
Bryan
Bryan
