Installing a ram mount
Plummit
Friend
I want to install a ram mount on the right side of my panel or side wall for a 796. Anyone done this on a -10 and if so, how? I bought a ram ball with a short arm and 2 holes (http://www.rammount.com/part/RAM-B-238U) as that looks like it will keep the mount close to the side wall where I want it.
TIA
~Marc
I have mounted several on the instrument panel. Just a couple of screw/bolt holes and nuts on the back side.
I used the ball mount that you referenced, with a short arm and Rams' X-grip cradle. Bolted through the panel just right of center. I wondered if the X-grip would be adequate to hold my iPad, but it has worked well in moderate+ turbulence.
