I have owned N12HR for about 10 months. The battery must be replaced. It is located between your feet in the lower part of the aircraft. To replace it will require the removal of the transponder, navcom, and cdi indicator. Also possibly other wires and vacuum hoses.
It appears that an access hole in the lower skin could cure this problem. Any thoughts or experences?
G Harben
N12HR
RV 4
G Harben
N12HR
RV 4
