I finished flying Phase I and last week took my first passenger (son) for a ride. Interphone is loud and clear on battery and ships power, but as I taxi out the interphone volume is very weak. After the flight we test the interphone volume on the battery and it is fine. I do another flight and the same thing happens. I troubleshot and found the volume loss on the intercom happens when the SL-30 is on and selected on the audio panel. If I switch the audio panel transmit to the 300XL #2 the interphone is fine. If I leave the switch in number 1 and turn off the SL-30 the interphone volume is also fine. It appears that there is some mismatch between the interphone and the #1 position on my audio panel, or internally in the SL-30. The internal interphone function on the SL-30 is disabled. I'm going to pin swap the two radios tomorrow and see if the problem follows or remains with the #1 position. Any other ideas? Anyone else with a similar problem?
Equipment list:
Sigtronics SPA 400 Interphone
King KMA 20 Audio Panel
Garmin SL-30 (Comm 1)
Garmin GNC 300Xl (Comm 2)
Equipment list:
