Neal@F14
Buy one, it's cheaper.
This!
And if you do build one, just keep telling yourself the way to eat an elephant is one bite at a time
I don't mean to derail this thread, but why do you have to enter your N number to get Av Fuel? I don't enter my license plate number to fill up my car. I may or may not just enter the easiest/shortest combo I can think of rather than my real N number.
I know this is a thread hijack, but...
You could "opt out" of the phone book (which is a private company) via unpublished or unlisted numbers. Mailing lists? Don't sign up in the first place (I know that's super-hard to avoid nowadays when even the grocery store has you home address).
But tying your N-number to your name and address and then making it available on-line is *exactly* the same as what the DMV does NOT do (publishing names and addresses of license plate holders). Know *why* they don't do that anymore? Because some nutjob got an actress' home address from DMV and killed her. (Not to mention that it allowed all sorts of other mischief, such as estranged spouses and abusive partners to find people).
I just don't think FAA (or other agencies) should be doing this. We've been lucky, as far as we know, so far.
FAA said:Are records are made public for safety. sf
#1. Don't leave until you have driven 10 rivets a day. #2. Wear a ball cap anytime you are close enough tp see your project. Dan
This is a biggee, I think. I have replaced a few parts due to edge distance issues, after following the plans exactly. Always double check where a hole will be on all parts involved, and adjust as needed for edge distance.
Chris
4) Take the time to periodically clean your workspace and put all the lesser-used tools away. To use a Trump-ism, this is "huuuuge!" to maintain positive gumption and a healthy mind set on the build. Sweep the floors, put all those stray clecos back in their boxes, post inspirational shots of finished RVs on the walls. Get in the habit of using that last 10 minutes to clean, and the next day's work session will be far more enjoyable (or at least tolerable, if you're dimpling wing skins and nursing a blister from pounding on a C-frame 1500 times ).
Have a refrigerator stocked with beer.
Planes are nice but spouses are better. Don't lose the latter while building the former.
