Hi all.
I'm nearly done with my HS - riveted the rear spar to the skin on the top side without issues, riveted it to the bottom right side...and then the holes on the bottom left side have a slight misalignment
Even though the misalignment is less than 1/32", that's enough to make the rivets not go in straight:
I'm pretty sure I drilled these straight, and had no mishaps while riveting the ribs. I followed the instructions religiously.
Any suggestions on what to do here?
I assume using a drill to make the holes match again is a bad idea?
I tried putting a little force to make it align, but it only makes the skin start to bulge, so I stopped.
The other thing is that it's about 40degF colder today than when I drilled these - the metal wouldn't deform this much with such a small temperature variation, would it?
Thanks everyone in advance!
