Rockologist
I'm New Here
Happy Easter everyone. Like many my first post here is a call for help. I just finished the HS-702 relief holes and was pleased with how they turned out, BUT I forgot to flatten the flanges you cut back leaving a slight rise in the surface of the HS-702 tab next to the relief holes. I cut the flange down so far I am no longer left with anything to bite onto to bend them flat. I used my die grinder to grind one down flat and the HS-00001 Does indeed lay flat now, but I fear I have thinned the metal flatter than probably desired. Possible maybe to just trim the tabs back past the flange? Should I order new 702s and try again?
thanks!
You can see the rise of the leftover flange on the right of the relief notch.
702-profile
Doubler wont lie flat
So I ground down the protruding flange.
Doubler now lies flat, but did I make the 702 too thin in the process?
thanks!
![2wu9wTm.jpg](/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F2wu9wTm.jpg&hash=887769aebf8666d6c393db5498fc9a33)
![P12QAls.jpg](/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FP12QAls.jpg&hash=16a96b416cf650059cdb4886768480bd)
702-profile
![VZ7TyIL.jpg](/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FVZ7TyIL.jpg&hash=b856b4d788339ad2b0f432363d9e41b4)
![WnIfGiE.jpg](/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FWnIfGiE.jpg&hash=b81f2be35d817046693f858ae3bb1f95)
![8X0RrU8.jpg](/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F8X0RrU8.jpg&hash=a6bdef239e4c9cef5264d94af3d98626)
