RV-6I would come at it from inside and go ahead and drill right through that skin as you're going to have to rivet it back in place anyway, right? Although I don't completely understand the rivet pattern there, which airframe is this?
So far the forward bulkhead looks good and my plan is remove after bulk head and inspect. If forward is cracked, obviously I’d replace. But if it’s sound I was planning on just replacing after bulkhead. I ordered two, one was sent and the other is on backorder.Can you drill out the aft rivet, and peel back the skin a little, to me looks like the rivet should be there, don't know why it was done underneath. Don't you need to take out the next vertical rivet line as well, for the other side of the bulkhead? With that drilled out, I would guess you can peel the skin back enough to at least see what you're working with better.
