How to bend the sub-panel
tims88
Does anyone have any good methods for putting the 7.3 degree bend in the F-1068A sub-panel? I can get good, crisp bends at both ends of the part but towards the middle I end up with more of a rounded curve. I've tried clamping the part to a workbench with the bend line right on the edge of the bench, with the bottom section hanging over the edge. I have a block of wood across the top to hold it flat to the bench while bending. Then I use another block on the small section to push it down. I've even tried preloading it as much as I can and then bashing it with a rubber mallet but the middle section just doesn't bend nicely like the ends do. Maybe it doesn't matter too much?
