Page 21iSU/-03. The CS4-4 in Figure 2, see attached. I have an electric puller, a pneumatic puller, and a hand puller. Only the hand puller has a chance, and once I get the nose over the rivet, I can't open the tool enough to get it to grab.
The July 2022 issue of EAA Sport Aviation has an article, Pull Riveting in Hard-To-Reach Places. Might be helpful.
Not an option to flip rivet to other side? Flush forward side in plans?
Section 5 tells you how to make a wedge to allow angled access to rivet. Section 5.4
I found this tool to work even better, and it doesn't get lost as easy as the wedges:
https://www.cleavelandtool.com/prod...vet-pulling-wedge?_pos=1&_sid=84382ac07&_ss=r
I took a cheap hand pop rivet tool and ground the nose off almost to the thread where the dies thread in. Works now in a lot of tight places.
Rivet gun and bucking bar.
I have a couple of swivel head riveting tools. They allow you to get the handle in a position where you can squeeze it in hard to reach areas. I've also had to grind the nose down to get access. If the rivet is still too close to the side piece you can use a wedge of some sort. Here is one that is similar to what I have on ebay. There may be better options available but I found a deal on a pair of them on ebay at the time I was looking.
