AAflyer
OK?I'm well into wiring my RV-8, and have a 40-tab "forest of tabs", aka FOT on my avionics bulkhead, (aft side of luggage compt.) and I have a small FOT on a longeron/rib in the belly, near my right wing root, where I plan to use for my wing-mounted equipment; lights, pitot heat, and rear-mounted transponder. This FOT will be convenient for my inter phone jacks, and PTT switches in the joysticks.
My question is; should I have another grounding point, other than the engine case, for any of my comm/interphone?
I've seen guidance that all grounds should terminate at the same place?
then, I've read that I need to isolate "some" of the grounds from others to avoid audio interference?
Could someone help me with this? Electronic ignition? Interphone? Radio? Strobes? Transponder?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm using Vertical Power Pro, and have a Dynon Skyview with ADS-B, EMS, single Comm with dual inter phones.
