So I helped this Gent when he first got his RV-12iS flying. I assisted in Phase 1 and never could get the AOA to calibrate. I told him, do some research and calibrate it later. I cut him lose to finish up Phase 1. He never got back to the AOA.
Coming up to his 2nd condition inspection, gave him a flight review and could see many things that needed attention. One being he never got the AOA set up. So we went up today to do the AOA Cal. Ahhhhhhhhh. No joy.
I read and watched videos one being "How to Calibrate Angle-of-Attack on Garmin's G3X Touch System - KITPLANES" by Paul Dye (This does flaps up only and uses a somewhat reverse order, not top to bottom to do Calabrations)
AOA Cal menu from TOP to BOTTOM as it shows on G3X AOA Cal Page. (Note what I think speeds should be, correct me if I am wrong)
> Stall Warning AOA Calibration (Start, slow to full stall, break, recover, calibrate, done)
> Caution Alert AOA Calibration (Min Control Speed, Pre Stall 45–50 knots)
> Minimum Visible AOA Calibration (User preference 85 knots)
> Approach Target (65 kts)
Another video did do flaps up and down, and calibrated top to bottom. G3X in the RV-12is has separate pages, FLAPS UP and FLAPS DOWN.
I am not going to get into every permutations of calibration, orders, techniques, did calibrate everything. Cleared and started over x3. AOA Cal Error window was showing. No AOA appeared on approach.
A descending-order of AOA correction values for Stall, Caution, Approach, and Minimum Visible AOA is expected. Failure to achieve this order results in an error. I recall we did have issues with these values.
If you have ideas, troubleshooting, checks, step by step, button by button, airspeed / config appreciate it.
RV-12iS leading edge AOA port (and spinner pitot) has issues being calibrated? Original aluminum pitot was replaced with the SS one. Since it is due for transponder check I am going to suggest he has Pitot / Static / AOA check for leaks. The AOA rivet was installed per plans.
