Kent Ashton
Chaps, my friend with a Cozy is having a hard time hot-starting his O-360, magnetos, & Silver Hawk FI. Here's what I told him but I am not a FI guy (I have an Ellison!) so check me on this advice:
After shutdown, the fuel spider is still pressurized and will dribble fuel into the cylinders. That excess fuel must be cleared by cranking the engine with throttle wide open and mixture cutoff for XXX number of turns (how many?).
If the throttle is cracked open prior to clearing the excess fuel, it will re-flood the cylinders and he may need to start over.
While cranking to clearing the excess fuel, keep the impulse mag on. If a cylinder fires he will know he has cleared back to a stoichiometric mixture and can enrichen the mixture (but how much?)
After a hot engine has sat for a while (how long?), the excess fuel will be evaporated by the hot cylinders and a relatively normal cold start procedure may be used (or a modified cold start procedure?)
I told him shutting off the high pressure boost pump won't help because mixture cutoff shuts down fuel to the injectors. Yes?
He tells me his engine starts well when cold.
TIA
Kent Ashton
Cozy Mk IV
TIA
Kent Ashton
Cozy Mk IV
