David-aviator
I have a Titan ECI IOX-360 in my RV7A with ram air induction. I am also running with dual 113 PMags. I am using the jumpers / with the MAP from the mags not coneccted to the MAP sensor. The engine has 100hrs on the hobbs and at ROP the cylinders are running with 1 the coolest, 4 next with 2 and 3 the hottest (365/385/395/400+ @ 8500 msl and 70 OAT @ 10.9 GPH LOP they nearly always break with 4 first then 3 then 2 then 1 (335/355/358/360 @ 8500 msl and 70 OAT) @ 6.8 GPH.
Cold start are flawless. Engine runs smooth all the way through taxi/run up / climb / cruise / landing / taxi to hangar / and shut down.....
Now for the hot start that is another question. (this is the only way I have found that will start the engine and I have nearly ????( there maybe one that I don't know about) tried them all).
1. Mixture full Rich
2. Master on
3. both PMags on
4 "clear prop"
5. turn on high pressure fuel pump
6. hit start
prop will turn maybe 10 times and the engine will begin to show life.
7. Let go the start bottom.
8. The engine will run rough ...but if I shut the fuel pump off to soon the engine will stop.
9. At a point in time about 5 seconds the fuel pump will be turned off.
10. Engine will still run but a bit rough and on a few occassions has back fired.
11. By the time run up is completed / and ready to launch the engine will finally run smooth but not as smooth as from the cold start.
NOW THE QUESTION..... Could this hot start problem be a PMag timing-set up problem? Or................
Frank @ 1L8 ...RV7A... Flying and Tracken MT-RTG
The problem is more likely vaporized fuel in the supply line.
This situation is why the AFP purge valve works so well. I have, after a year of trial and error, gotten the hot start procedure down to where it works 99% of the time - the engine starts on the first or second blade. The 1% where it does not work is when the engine is half cooled down and the pure hot start procedure does not quite work due to fuel starvation.
I won't bore you all with how to do it (it is quite simple) just advising anyone wondering if AFP is the way to go on this issue - it is in my book.
