strahler13
I am troubled with high cylinder temps on my initial flight of the day. My equipment: RV-6, O-360, 1,000 hrs, Lasar ignition/Slick Mags, VM-1000 monitor.
Usually on my first climb out, my temps climb to about 430 deg, then level off and drop when leveling out. I can do a touch and go and the temps only climb to about 375. Normal cruise is about 360.
I replaced the intake gaskets and checked for induction leaks and rebuilt the baffle seals. Fuel flow on initial climb is about 17-18 gph. I turned off the Lasar system on one test flight with no change. Mags were recently inspected and are fine.
All cylinders run about the same temps with 2 and 4 slightly higher. Both cyl and EGT temps are quite uniform in cruise. All four cylinders are monitored so I doubt it is a probe problem. The Lasar monitors cyl temps and the probe checked out OK.
Oil temp is fine and I can keep it below 200 even on the hottest days.
Anyone have any ideas? Does the Lasar system "run" the temps up initially? Looking for answers, and thanks in anticipation.
Mark
Mark
