Hi together,
I rebuild the new horizontal stabilizer and elevator with the improved design for my -8.
In some points the building instruction is a little bit confusing, particular with the new doublers at the HS spar.
I have questions concerning the doublers in the elevator spar at the rod ends:
Do I need to drill ALL prepunched holes (see picture) in the doubler through the spar and reinforcement plate?
Should I drill/ream the hole for the rod end bearings?
Thanks you,
Anna
Thanks you,
Anna
