Im hoping someone can help to answer a couple questions on my high oil temp.
Has anyone ever had a Vernatherm go bad or stick?
What size cooler are you using for a 200HP IO-360 and what size inlet/scat tube size feeding it?
Where and how are the coolers mounted?
I have a 13 row Positeck being fed from a 4" scat coming off the rear baffle behind #3 and am having 220-225 most of the time and it's just now starting to warm up weather wise.
What temps are most of you seeing with a similar cooler set up?
Any ideas???
Any ideas???
