Hi VAF.
I am experiencing a rather high idle speed out of the gate after doing the mechanical carb synchronization according to the RV-12 MM. It's sitting at about 2500 cold, and then 2600 as it warms up. It takes a full CCW turn of the idle stop screws on both sides to get to 1800, and another 1/8 ish of a turn to get to 1650. The RV-12 MM is a little ambiguous whether the limit of 1/2 turn on the idle stop screws only applies for making the two sides synchronized at idle, versus also applying to the idle speed.
I am also experiencing some variation in the off-idle synchronization over the range of the throttle. If I synchronize at 2500, it is off at cruise RPM. If I synchronize for cruise, it's off at 2500.
The carbs were recently overhauled. I took them apart twice now after seeing this behavior to see if everything was reassembled correctly. I did not find any issues, everything seemed exactly how it should be. The carbs are seated in the sockets properly. The sockets are brand new. The socket clamps are tight to the spacers, and the carbs are snug in the sockets. The air filters were recently cleaned and re-oiled, and they are snug and seated well on the carbs.
I've redone the entire synchronization procedure exactly according to the MM four times now and I'm getting the same result every time.
Maybe I'm being too picky. Maybe this is all totally normal? It's not grossly off, but it is noticeable. And the idle thing seems to be totally fine if I just make the adjustment to where I want it and ignore that 1/2 turn thing for setting the speed.
Unfortunately, I do not know whether this was occurring before the carbs were worked on.
Any thoughts on this, anyone?
