As I've written in a previous thread my #2 CHT has typically been 20-30 degrees higher than all the others whenever the cowling is on and even during flight. With the cowling off and the engine at idle all CHTs are within 5-10 degrees and typically stabilize around 290 after 15 or 20 minutes (std day).
During flight at 6000ft DA, 75% power, full rich, CHTs were nominally in the 330-350 range with #2 upwards of 360.
I checked every possible place for an induction leak, compression checks, and worked the baffling and filled every possible gap I could find and still temps on #2 were much higher. It was particularly bothersome while taxiing or at idle for extended periods of time in which #2 would climb to as high as 380 prior to take-off then into the 420's during climb out. It would always come back down to 360ish once I leveled off though. I just couldn't figure it out. Then I stepped back and noticed something which has been right in front of my face the whole time:
Notice the 1/8" gap between the upper and lower cowl at the fwd outboard inlet. I never sealed this gap for some reason... so I tried this:
All CHTs dropped at least 20 degrees at 6000ft, 75% power, full rich, and more importantly #2 is within 10 degs of all the others (still the highest though) and never goes above 400 even during 100-110 mph climb full power.
Obviously enough air was passing through this gap, and the one on the other side, to limit cooling airflow through the entire engine.
To ensure this was the cure, I conducted the test with tape on and off three times in succession under the same test conditions. Results matched each time.
So for those still building - go ahead and seal this area. For anyone currently flying and have a little gap here, seal it with some good tape and see what happens. My cowl is secured with Skybolts exclusively and I've found they do have a little play - the result of which is this gap. Who knows it may even be a little larger during flight.
I'll probably layup some glass and resin and inside with the two cowl halves together using wax and release agent on the upper cowl surface.
Thought I'd share...
Ken
![2mw6tep.jpg](/proxy.php?image=http%3A%2F%2Fi52.tinypic.com%2F2mw6tep.jpg&hash=26353b0917bb58b45ded334360c6dedd)
![9up3jo.jpg](/proxy.php?image=http%3A%2F%2Fi54.tinypic.com%2F9up3jo.jpg&hash=570a28d4a7eec31f34ca9e14df061dc1)
Ken
