A tail wheel lifter can be easily constructed from the Harbor Freight 4-Wheel hydraulic Lift #60395 by bolting on a piece of aluminum channel in place of the cross channel and wheel holders. No modifications were made to the HF Lift. I used a 6061 T6 3? x 1.5? x .258 x 12? long channel and a ?-13 grade 5 bolt. Also added a piece of 1.5 x 1? alum U-channel underneath, which may not be necessary. Lift or ramp the tail wheel over the front of the Lift?s frame. The lift raises the tail about 25? and it can be locked in place.
