missinggear
Member
I know the primer question is a long fought discussion on the forum.
As a new builder, I am priming the skeleton in the HS/VS (so far) but notice when I am riveting the skins on the bucking bar is leaving some marks, scuffs on the primer so delicately applied ? mainly to the ribs. (As I am checking my work).
Question to the experienced: Should I be concerned with the scuff marks? Should I re-apply the primer in the areas?
[Note, I generally search the vast experience of the forums first, but could not find an answer]
Thanks in advance.
Thanks in advance.
