blueflyer
I test ran my Lycoming 180 hp engine with my new dynavibe hooked up. It read .7 IPS at 300.
Will someone check my math here please:
weight=((180/10)+30))*IPS
weight=48*.7
weight=33.6 grams
Since I am putting bolts through the existing flywheel holes, do I install 33.6 grams, or do I double that weight and install 67.2 grams?
I understand that the weight should be installed 180 degrees from 300, and the rotation should go in the same direction as the prop spins.
weight=48*.7
weight=33.6 grams
