I just finished the canopy and creating the fuel and break lines inside the fuse, I have the pump cover completed. Now what?
Do I install the landing gear or do the avionics and electronics first while the fuse is low to the ground? Do I do the firewall forward and engine fitting before gear and avionics?
The manual just kind of drops off at this point... Need some guidance. Thanks.
