Just a heads up guys. I could not get fuel pressure from either pump.
So I assumed it was the sensor. I put an ohm meter on the legs and with pumps working no change in readings. OK thats easy new sensor .Dynon sent one out. NOT still no pressure reading . Got to looking at things and there is an orfice inside the bolt that attached the returned and pressure line. Bingo you cant get pressure readings that way. I removed it and have good fuel pressure readings.
I am thinking that bolt (painted yellow on top) is for hooking up a return line with out a sensor hose. Some installations that would be fine. Not on the RV 12 we already have a restirction in the return line.
I have advised Vans on this. I am sure they will be putting something out on this. If you want just take a look at your bolt(yellow paint on top) you will see that there is an orfice you can remove from it.
Brad Stiefvater
Brad Stiefvater
